Regal_GS_1989 Posted March 26, 2006 Report Posted March 26, 2006 Alright, i got a question about steering wheel controls. The controls in my cutlass dont work at all. where would i start looking to find the problem with them? Also, would a bad turn signal switch cause them to not work? I know that you have to pull the lever toward you slightly for the signals to work. The car has a factory CD player and Electronic climate control. Quote
turby Posted March 27, 2006 Report Posted March 27, 2006 The turn signals and contacts for the radio controls are both in the TSS. BUT they are seperate from each other so it could be totally unrelated. Could be the contact ring under the steering wheel, the contacts on the TSS, the controls themselves or the little box under the dash. Do the heater controls work on the wheel? Quote
Regal_GS_1989 Posted March 27, 2006 Author Report Posted March 27, 2006 Nope, the heater controls dont work at all on the wheel Quote
THe_DeTAiL3R Posted March 29, 2006 Report Posted March 29, 2006 FWIW it IS possible to put a non-radio button switch in a radio-button column on a ~88 GP. I know cause I did this. Quote
Regal_GS_1989 Posted March 29, 2006 Author Report Posted March 29, 2006 moving to audio Thanks for moving it. i wasnt' sure if i should put it in here or not cause it also involved the climate controls. FWIW it IS possible to put a non-radio button switch in a radio-button column on a ~88 GP. I know cause I did this. Im pretty sure that the signal switch is the right one. There is a wiring harness from the horn pad that is plugged into the signal switch. Neither of my regals have had any of the typical W-body Bullshit. Keep any thoughts comming, and i'll just have to play with it once i get the time. Quote
Brian P Posted March 29, 2006 Report Posted March 29, 2006 it probably is the cancel cam that has the four contacts. Either it's gummed up or fried. Quote
TheEddie Posted April 8, 2006 Report Posted April 8, 2006 I know that you have to pull the lever toward you slightly for the signals to work. Yay! Reminds me of my 96 GP SE...to hell with turn signals, just use your hand! Quote
