Turbo Crossover
WIll a 1990 STE turbo crossover bolt to a 3100 v6 or do i need to buy the manifolds to? thanks guys
You will obviously need exhaust manifolds from one of the engines. You will have to atleast cap off the rear 3x00 manifold IF the crossover will even bolt to it. You can't flip around a front one either to use. You can use the turbo exhaust manifolds but they have different port shapes than the 3x00 heads have so you will have to attempt to port them the same shape if you went that route....
okay so i need to get the manifolds to does anyone know what i can use to tune this thing once its all on there cause i want to run it safely as a ican cause i dont want to blow it up yet
You have to use the turbo manifolds. Will bolt up with some grinding to get the D shape as said. Don't forget the down pipe and injectors. If you have a doner car get everything.
I think you should do alot more research before you take this endever on. :rolleyes:Get Corky Bell's book and read it 6 times. Google turbo and start reading. Search this site and the TGP site.
Just my 2 cents.
Good luck
Jud
