gp2001 Posted March 20, 2006 Report Posted March 20, 2006 Anyone have experiencing getting these things off the plugs? There's a heat shield around the boot, and I'm not sure if this just comes out when the boot is pulled off the plug, or if its held onto something. Quote
19902drlumina Posted March 20, 2006 Report Posted March 20, 2006 they come off with it sometimes they fall off while removing. just like any other plug wire just twist and pull. Quote
sl3196 Posted March 20, 2006 Report Posted March 20, 2006 Push down on heat sheat then twist and pull. They will come off with plug wire. Quote
mfewtrail Posted March 22, 2006 Report Posted March 22, 2006 Push down on heat sheat then twist and pull. They will come off with plug wire. That's how I do it. I suggest you pick up some cheap plug boot insulators to replace the stock metal ones as they can be a pain to remove sometimes. I use these insulators on my GTP, they're probably about the cheapest ones you'll find. http://www.cableorganizer.com/insultherm-spark/ Quote
gp2001 Posted March 23, 2006 Author Report Posted March 23, 2006 Thanks for the replies. Dumb question though - when you say to push down on the heat shield, do you mean down toward the engine, or straight down toward the ground? Quote
