willsv8 Posted March 20, 2006 Report Posted March 20, 2006 the int lights stay on had to pull the fuse .did a search came up with it needed a new headlight switch. well i put a new one in with no luck i'm at a stand still with no int light. please help hate to be left in the dark info on car=1989 cutlass int 2 door 2.8 auto Quote
cutlsp Posted March 20, 2006 Report Posted March 20, 2006 check your door pins one might be busted off.......or not working Quote
willsv8 Posted March 20, 2006 Author Report Posted March 20, 2006 check your door pins one might be busted off.......or not working is there a way to check the door pins ?the pins push in ok thay look to be fine. how do you take them out? Quote
cutlsp Posted March 20, 2006 Report Posted March 20, 2006 I haven't gotten that deep into my car yet..... the door pins if they push in then might be fine you could have a pinched wire that is grounding the interior light circuit. meaning that the lights are staying on and if thats the case you could either put in a fresh wire or use a quick fix of electrical tape. the MAIN point it could be pinched at IMO is under neath the passenger side A piller where the lighting wire runs down to the fuse block or on the fuse block its self. I mean i can't tell 100% without seeing the car for myself i've been chasing shorts on my 88 for about 2 years now so i don't know if i'm going to be much help if any :oops: Quote
willsv8 Posted March 23, 2006 Author Report Posted March 23, 2006 well found what was wrong ! it was the pass/door pin ! now i'm not left in the dark Quote
jeremy Posted March 24, 2006 Report Posted March 24, 2006 well found what was wrong ! it was the pass/door pin ! now i'm not left in the dark glad to hear that it was something simple Quote
blkinternational Posted March 27, 2006 Report Posted March 27, 2006 im having the same problem my int lights wont go off so i pull the fuse and then ill put it back in some other time later like a few weeks and itll work fine for like a day then it will do it again.... i have this problem ontop of the dashlights not working still... but i found that when i had the fuse in for my int. lights the dash lights would work fine then the second i pulled the fuse the dash lights went off again WTF????????? and the light behind the armrest wouldnt go off so i had to pull the bulb out and i recently went to a junkyard and picked up a new headlight switch to se if that was the problem but it wasnt so wtf i dunno what to do now????????? Quote
willsv8 Posted March 29, 2006 Author Report Posted March 29, 2006 the door pins are easy to do!! i just put 2 new ones in. now i'm good to go Quote
