speaker depth for 95-01 lumina
does anybody know the max speaker depth- top or bottom mount- for 95-01 lumina front doors? I'm going to put some components up front, and the ones i'm looking at are nearly 2.6" deep, bottom mount.
If anyone knows that would be awesome, it would save me the trouble of taking off the door panel and measuring it myself.
i'll be putting a new door latch assembly into my mom's 95 lumina tonight or tomorrow. i'll see if i can't get you some measurements
ok, so from the mounting surface of the door you have about 1 and 3/8 inches. that gives you about a 1/8" gap between your magnet or enclosure back to the window.
from the surface of the door to the speaker surface of the speaker pod is:
at the shallow end 5/8", and at the deep end 1.5"
i suspect that if you mount them any farther than that from the surface of the door, you will have to do some trimming on your door panel because the speakers sit pretty clos to the panels.
hope that helps you
thanks! the speakers i was going to buy were 2.5" deep, time to do some shopping. :(
I dont think your going to find very many speakers at all, or even component sets where the speaker/midrange woofer is smaller than a 2.5" mounting depth...
Well i'm going with PG Xenon x5.0 components. They're supposedly 2.57" with the protective rubber boot, or ~2.2" without. I hope they fit.
