lost 5th and reverse, WTF??
any of you other 5spd people have this problem? was working just fine, then i pulled up to a spot to park, put it in reverse and it went forward instead. so now if i try to put it in 5th it goes into 3rd, and if i try to reverse it goes into 4th. i think it must have something to do with the right hand cable, but i just don't know what....it does seem kind of loose in there though
i'd bet you're right, sounds like a cable issue and not an internal issue.
:werd:
Guest TurboSedan
definately sounds like the crossover cable to me (cable for side-to-side movement)
Yeah, the cables are expensive too. But better than replacing a trans.
FWIW: Only 1 of the 284 cables are still available.
yeah i was just under the car and i can feel where the cable is frayed. nice and tucked away under friggin everything....super
I know this is a long shot but... would a shifter cable from a calais work? I mean both the cutty and calais came with 5spd's both had quad 4's?
I only ask this because I was trying to find a listing at work, but found the calais with a 5spd trans. Theres two different size cables.
Just a question I had to ask.
I can get you cables but they're $$.....from a GP with 60 k on it....
55 cdn a piece..let me know and I can make a call if you like.
cool man, that would be great. cause my friend who works at a garage said that its a negative on anyone having it
