molbly Posted March 13, 2006 Report Posted March 13, 2006 What would you recomend for removing ust or covering it up.. For 1990 4 door lumina Euro edition. I am on a budget so I would like to do it cheap.. Quote
SigEpCutlass Posted March 13, 2006 Report Posted March 13, 2006 Is it on the body or the undercarriage? I don't know much about the body, but I might have a few suggestions for the undercarriage. Btw you did a double post and the other one will probably get locked or deleted. Quote
THe_DeTAiL3R Posted March 14, 2006 Report Posted March 14, 2006 Use a grinder or a wire brush wheel for a drill, and GET THE RUST OFF. Then cover it up with some spraycan primer and Duplicolor spraypaint. May not look perfect, but getting the rust to stop is most important. Rust is like CANCER. Quote
fastbird232 Posted March 14, 2006 Report Posted March 14, 2006 Yeah, take all the surface rust off and about an inch of paint on all sides of the spot to be sure. Then paint it immediately. Quote
ToroToro Posted March 14, 2006 Report Posted March 14, 2006 Where exactly is it on the car? Painting it wont really help if it's hitting it from behind. Quote
logikf1ve Posted April 4, 2006 Report Posted April 4, 2006 Use a grinder or a wire brush wheel for a drill, and GET THE RUST OFF. Then cover it up with some spraycan primer and Duplicolor spraypaint. May not look perfect, but getting the rust to stop is most important. Rust is like CANCER. Some primers are penetrable by water, therefore priming the part won't really make much difference. Edit: shit. I just looked at the date of this thread. My bad. Quote
