Monkton Posted March 12, 2006 Report Posted March 12, 2006 My car isn't hitting all cylinders. Leaving a friends house its top speed was 38mph. Something like this has happened before and it was an ignition coil. I put the pedal to the floor and it barely goes. I believe it's an ignition coil, like before, any other possibilities? Quote
GutlessSupreme Posted March 12, 2006 Report Posted March 12, 2006 coil, wires, spark plug(s), CPS... but ya, most likely another ignition coil, from the sound of it. That'd mean you lost two cylinders, whereas wires/plugs you'd probably only be missing one. and the CPS just retards the timing if it's not working properly (or working properly and detecting too much knock) Quote
Crimson Fury Z Posted March 13, 2006 Report Posted March 13, 2006 if you are going to do one, replace all 3 and the icm Quote
Monkton Posted March 15, 2006 Author Report Posted March 15, 2006 I don't have 3, I have 2. Mine's a 4 cylinder, not a 6 (at least I think that's what makes the difference between 2 and 3). I got a new ignition coil and checked the two in their already, and it was the replaced one that went again. So luckily it was still under the one year warranty . Kind of hard to believe that the other one hasn't gone yet. Quote
5speedz34 Posted March 15, 2006 Report Posted March 15, 2006 You have a 4 cylinder? Do you have a lumina? Not many of the cars around here have the 4-bangers, oh and I would just check the coil that's what it sounds like. Quote
Toxie Posted April 9, 2006 Report Posted April 9, 2006 if you are going to do one, replace all 3 and the icm I second that... Quote
ToroToro Posted April 9, 2006 Report Posted April 9, 2006 I'd just replace the failing coil and be done. No need to kick a lot more money into replacing coils and an ICM if they are still good. So you have the Quad 4 then? Quote
