BuickMan Posted March 12, 2006 Report Posted March 12, 2006 I went to change the spark plugs and the ones in the rear are blocked from the top and bottom. Am I going to have to pull the engine to get to the spark plugs? Is there an easy way to do this? Quote
sl3196 Posted March 12, 2006 Report Posted March 12, 2006 SEARCH BEEN COVERED 4000000000 times. Quote
Crazy K Posted March 12, 2006 Report Posted March 12, 2006 read FAQ!!! how to rotate an engine. http://www.w-body.com/forum/viewtopic.php?t=39670 Quote
BuickMan Posted March 12, 2006 Author Report Posted March 12, 2006 remove 2 motor mounts and rock the engine forward..jesus christ.. why in the hell would GM engineer a car where you cant reach the freaking spark plugs Quote
Crazy K Posted March 12, 2006 Report Posted March 12, 2006 so simple to do, yeah it's intrigueing that they did such a thing, but, oh well.... at least you don't have to crawl beneath the car and disconnect some mount at the lower rear of the engine to rock it... be glad it is quite simple, once you know how to do it. Quote
5speedz34 Posted March 12, 2006 Report Posted March 12, 2006 remove 2 motor mounts and rock the engine forward..jesus christ.. why in the hell would GM engineer a car where you cant reach the freaking spark plugs Are you shitting me? Have you looked at any new cars? These cars are the easiest things to work on. Ohh and it sucks for us 3.4 guys. I've had to drop my engine 3 times to do the plugs. :x Quote
NOHC_WBody Posted March 12, 2006 Report Posted March 12, 2006 Ohh and it sucks for us 3.4 guys. I've had to drop my engine 3 times to do the plugs. :x Pull the weatherstripping where the rear of the hood meets the sheetmetal, a couple of long extensions and a u-joint or two and the rear plugs are in your hand in 10 minutes or less. Quote
5speedz34 Posted March 12, 2006 Report Posted March 12, 2006 Ohh and it sucks for us 3.4 guys. I've had to drop my engine 3 times to do the plugs. :x Pull the weatherstripping where the rear of the hood meets the sheetmetal, a couple of long extensions and a u-joint or two and the rear plugs are in your hand in 10 minutes or less. You suck at recognizing sarcasm..... Quote
NOHC_WBody Posted March 12, 2006 Report Posted March 12, 2006 Ohh and it sucks for us 3.4 guys. I've had to drop my engine 3 times to do the plugs. :x Pull the weatherstripping where the rear of the hood meets the sheetmetal, a couple of long extensions and a u-joint or two and the rear plugs are in your hand in 10 minutes or less. You suck at recognizing sarcasm..... *slaps forehead* Quote
19Cutlass94 Posted March 12, 2006 Report Posted March 12, 2006 Ive never had a problem gettin to the rear plugs. Never had to remove the mounts or anything. I duno why everyone has such trouble. Quote
Crazy K Posted March 12, 2006 Report Posted March 12, 2006 3.1 and 2.8 have larger intakes, with longer runners that blcok off access to the rear of the engine. read the thread above for pics! Quote
5speedz34 Posted March 12, 2006 Report Posted March 12, 2006 Yeah, you shouldn't need to do that for a 3x00 motor. But rocking any GM engine helps to do the plugs. Quote
GutlessSupreme Posted March 12, 2006 Report Posted March 12, 2006 Are you shitting me? Have you looked at any new cars? These cars are the easiest things to work on. x2 these are some of the easier modernish V6 cars to work on there bud Quote
19Cutlass94 Posted March 12, 2006 Report Posted March 12, 2006 I know my engine is rather easy to work on, but I dont find the older ones that hard either. Quote
DaveFromColorado Posted March 12, 2006 Report Posted March 12, 2006 I've never had a problem doin' the rear plugs ... just lay across the top of the engine bay, and reach down from one of the sides... I've always done it that way, and never had a problem... even on my 88 Regal I did it that way. --Dave. Quote
GP1138 Posted March 13, 2006 Report Posted March 13, 2006 Dude, your question just got sigged. And yes, it's strange, but it's necessary. Quote
cutlsp Posted March 13, 2006 Report Posted March 13, 2006 you could also just remove the altenator braket and rock the engine forward this will give you a TON of space to replace the plugs. Quote
94 supreme Posted March 13, 2006 Report Posted March 13, 2006 i actually have a tool u put in place of one othe top motor mounts and u ratchet it so the tool closes and it rocks the motor all the way to the radiator and its easier then hell to replace them 8) Quote
one_fast_prix Posted March 20, 2006 Report Posted March 20, 2006 where did you pick something up like that? Quote
THe_DeTAiL3R Posted March 20, 2006 Report Posted March 20, 2006 Hurry for another fucking MULTIPLE PAGE spark plug thread! Quote
