HELP!!!
so i jsut got done doing my intake gaskets...and now my car wont start ive got spark...and i think i got fuel just how do i check that???
any other ideas..
and im pretty sure everything is hooked up right
btw it is a 1995 3100
ya got everything plugged in correctly? This is something that gets overlooked too often.
--Dave.
well, there should be a schrader valve on the fuel rail, you can press that in with a key or something and it'll spray fuel out - that's how you know you've got fuel, altho it doesn't test the injectors to see if they're spraying.
--Dave.
so the two wires coming from under the upper intake manifold...do those connect to the coolant temp sensor???
Yup, but the car should run without it
the schrader valve should be somewhere on the fuel rail itself.
--Dave.
where at??? b/c there is a round dial type of thing but it is below my upper intake...
The valve should be under the upper intake, sticking out the left (alternator) side....
The pressure port is on the end of the rail on 3X00 motors, right between the alternator (as C-Bad stated) and the power steering reservoir.
