Would this work?
2 channels = 2 speakers
4 channels = 4 speakers
You could do it, but the amp wont last long, and not to mention you wont have any fade control, so if your front speakers, or rear speakers, are over powering, you wont be able to do anything about it...
it will power six. those amps are stable enough. I ran a 4 channel with 2 channels running all cabin speakers on high range. and the low range on 1 10 inch sub. thats mixing all types of resistence, but its a 1 ohm stable.
sure you could, run front and rears sets in parallel for a 2ohm resistance to the amp, you wont have a Left-Right balance, but u will still have front-rear balance. This is assuming that the amp can handle 2 channels at 2 ohms. What are the specs on the amp?
