I just put a used transmission im my 93 z34 it wont shift out of first gear
and speedo does not work now any ideas plmk thank you john
is the linkage on correctly if so is it the same type of trans (year)? also did you hook up the speedo sensor?
if in doubt about the transmission....
find and read the tag on the right rear side of the tranny...
I do this by removing the right tire and using a mirror and flashlight......
read this it shows the tag info and tran info:
http://dtcc.cz28.com/transmission/index.htm
this covers 93:(and is linked insid eth page above...
http://home.att.net/~subzero350/1993_4T60-E.pdf
Your tranny must be from a 3.4 model only, and may be limited to a 91-93 or 94 model only... anyone else certain>
Well, if the speedo doesn't work, and it is for sure not a cluster problem, than that would definately cause the trans not to shift out of first gear. The shifts are electronically controlled, so if the ECM is getting a speed reading of 0, the trans will not get the signal to shift. It could be a number of things. First thing to check would be the Speed sensor, and than work your way from there.
all good now .thank you for the info you guessed it the plug to the spedo was not plugged in all the way and i was in a bad mood and not thinking strait. :D
