GP1138 Posted March 11, 2006 Author Report Posted March 11, 2006 My car is dirty as hell, but NO SAG!!! Like I said, the bumper is next. It looks like 200lb of bird shit. Quote
5speedz34 Posted March 11, 2006 Report Posted March 11, 2006 Awesome! What's wrong with the bumper? Quote
White93z34 Posted March 12, 2006 Report Posted March 12, 2006 i'll keep an eye out for you john, i swear i see tons of GPs same color as yours in junkyards all the time. Quote
Crazy K Posted March 12, 2006 Report Posted March 12, 2006 when you get a new one.... save the old valence for me!!!!! I only need it to section it!!!! Quote
luminal67 Posted May 12, 2006 Report Posted May 12, 2006 I bought a set of those white blocks that go under the leaf spring ends. Kind of a pain to get in, but nothing a hammer won't fix. how well have these worked for those who have installed them? ride height, noise, whatever. Quote
tdaye Posted May 13, 2006 Report Posted May 13, 2006 they are what i've used on both my Cutlass, only replaced them once and I can say that they are quiet. I would think the raise the car ever so slightly compaired to the rubber pads that were on originaly.I wasn't aware that you could get anything other then them for replacements. Quote
luminal67 Posted May 13, 2006 Report Posted May 13, 2006 yea, i am kinda sitting higher in the rear now. Guess i'll have to get some subs or something to weigh down the rear. Quote
Lee Posted May 20, 2006 Report Posted May 20, 2006 It managed to level my car out from it's saggy rear, about 1/2 inch rise I's say. I was already running a size smaller tires in front [my ABS loves me]. Wish I had high rear end problems. I'd rather that than rear sag. Makes it look getto with a car full of drivebyers. It is really bad when I bring home a thousand pounds of retaining wall blocks. Sits on the rubber bumpers then....I try not to do that a lot. Last year I brought home over 4 thousand pounds of block in four trips. Now I try to stick to 12 bags of ceder mulch at a time. Much less stressful. Quote
Navybass Posted May 21, 2006 Report Posted May 21, 2006 I was looking at another thread and there were some white monoleaf pads that you put at the ends of the monoleaf to bring the rear end of the car back up to normal ride height. Where can I get some? I really need them. Quote
Supreme Cutlass Posted May 21, 2006 Report Posted May 21, 2006 I was looking at another thread and there were some white monoleaf pads that you put at the ends of the monoleaf to bring the rear end of the car back up to normal ride height. Where can I get some? I really need them. NAPA Quote
jmoss21 Posted May 21, 2006 Report Posted May 21, 2006 how does one install there my car is sagging Quote
GP1138 Posted May 22, 2006 Author Report Posted May 22, 2006 http://www.w-body.com/forum/index.php/topic,39878.0.html SEARCH. This is the second thread about this on this page. I did them on my car and they look like a pain in the ass but they're not. You'll want to remove the bolts and nuts for the traling arm and swing it out of the way. Put a block of wood on your jack and carefully jack up the monoleaf on each side. Scrape the remaining pieces of pad out with a flatblade screwdriver or something, I had to use a hacksaw myself. Then just hammer the monoleaf helper pads in there underneath the monoleaf. Voila, you're done. Quote
Lee Posted May 23, 2006 Report Posted May 23, 2006 I just jacked up the monoleaf, using a support board so as not to damage the fiberglass monoleaf, rounded the front edge of the plastic block with a grinder, and wedged them in. One side was tough because the rubber pad on the monoleaf was still there. I greased up the top of the block and tapped it in. I removed nothing. Quote
UWISHU1 Posted November 17, 2006 Report Posted November 17, 2006 would replacing these remove the annoying suspension squeak from the back? Quote
Crazy K Posted November 18, 2006 Report Posted November 18, 2006 would replacing these remove the annoying suspension squeak from the back? Only if the noise you hear is the ends of the monoleaf rubbing on the the spindle/knuckle assembly. Quote
kanwisch Posted November 28, 2006 Report Posted November 28, 2006 Good write-up GP1138. Makes my future work easier Quote
kaptnjack Posted April 3, 2008 Report Posted April 3, 2008 I have recently purchased the isolators but have yet to install them. For my 93 cutty ragtop. I found them at O'reilly auto Parts Monoleaf spring Isolator Pads Moog Part K6544 Lifetime warranty $19.99 plus tax for a pair. Quote
rockfangd Posted April 6, 2008 Report Posted April 6, 2008 i just did mine a few days ago and even with removing the wheels and checking my brakes it took 10 minutes Quote
jake63 Posted April 16, 2008 Report Posted April 16, 2008 I did mine on 94 cutty. You can use a 6" c-clamp and block of wood from leaf to bottom strut bracket to raise leaf. You should definitely remove the old rubber ones first ( i used a putty knife ). Then just smack these in with a hammer and length of 3/4 thick wood. The slots, however, face down. They are available from rock auto online also, part# K6544 made by Moog. In suspension under "transverse spring isolator pad" Quote
rockfangd Posted July 13, 2008 Report Posted July 13, 2008 that is exactly what i did. everything Quote
shyguy164 Posted July 14, 2008 Report Posted July 14, 2008 I just installed my 2nd set of these blocks. They "only" last like 50k miles or so. Someone said on the the slots face up and the end of the spring goes into them, that is not true, they go the other way. My mechanic didn't know about these, he tried to sell me the new rubber ones for like $75 installed. Quote
