gmrulz4u Posted April 2, 2003 Report Posted April 2, 2003 The drivers side window in my 89 Supreme is really starting to annoy me! It's rattling with ever little bump in the road. It's not overly loud, but definately audible. I don't hear anything with the window all the way down, but all the way up, it's pretty bad. Besides telling me what the problems likely is, could you also tell me how expensive and how hard the replacement would be? THANKS! Quote
JS91Z34 Posted April 3, 2003 Report Posted April 3, 2003 The seal on the back window of my Z34 was dry rotted, and it rattled BAD! It was like 150 bucks to get it professionally done if they didn't break it. Then it would have been close to 900 bucks for a new back window. The side windows could just need to be adjusted. Those side windows on the w-bodys' are expensive, at least around here they are. I would check to see if something might be loose or broken that can easily be fixed. Quote
musthavemuzk Posted April 3, 2003 Report Posted April 3, 2003 are you sure it is the window? it could be a loose handle or the piece that is fastened to the car might be loose. i have this problem on my drivers side. about avery 2 months i need to retighten it. Monty Quote
gmrulz4u Posted April 3, 2003 Author Report Posted April 3, 2003 Thanks, but I'm 100% sure it's the window... Quote
supreme_style21 Posted April 3, 2003 Report Posted April 3, 2003 My '94 does the same thing. It rattles when it's up all the way, but if it is down even the slightest bit, its quiet. Quote
JS91Z34 Posted April 4, 2003 Report Posted April 4, 2003 Check those window tracks out and the slides and sliders on the window itself. Quote
godofthunder Posted April 4, 2003 Report Posted April 4, 2003 When mine is down (esp. in the drivers door), it rattles when you shut the door, really annoying Jon Quote
