Here's a writeup describing one *more* process to get to the rear spark plugs; Rotating the engine via prybar.
*Disclaimer: I am in no way responsible for damages you create using this writeup*
Roatating the Engine:
1)Engage the parking brake and put the transaxle in neutral
2) Unscrew the front dogbone bolts and flip them up
3) partially put the bolt into the right bracket as shown
4) Pry the engine foward by sliding the left bolt back in and prying as shown
5) Slide the bolt on the right bracket into this lobe to hold the engine, and you're done!
contributed by Supreme Cutlass
This topic is now closed to further replies.
