91GranSport Posted April 2, 2003 Report Posted April 2, 2003 I have a problem with my power mirrors. The driver-side power mirror can move up and down but it does not move left or right. However, when I switch control to the passenger-side mirror, it moves both up and down as well as left and right. What can be the cause of this, and how can I fix it? Thanks. Quote
NeverSayDie Posted April 2, 2003 Report Posted April 2, 2003 There are these threaded...thingumabobs on the back of your mirrors that make them move. Sometimes, if they are worn, the mirror goes too far out and hey can't thread back in to move the mirror. Try moving it by hand while pushing the switch in the same direction. They thingumabobs may catch, and it'll start working again. There may be something else with a better explanation than this though. Does it make any sounds when you push the control? Anyways, I had a similar problem, but my thingumabobs were so worn that my mirror fell out going down the road. Quote
ismellrealbad Posted April 2, 2003 Report Posted April 2, 2003 punch the left or right side of the mirror.....youll hear some clicking at which point you think you broke it, but you actually fixed it. youll jam the threded thingamabobs back in like 91GranSport said. See? violence works wonders!! P.S. pushing its lightly on the left or right side will work also, but as always i recommend kicking or punching Quote
Jon Forston Posted April 8, 2003 Report Posted April 8, 2003 Had this problem. Are you good at soldering? You need to take the switch apart. Most likely there is a broken trace, which needs to be replaced with a wire. ( follow where the trace was supposed to go, and solder a wire from the starting point, to the ending point.) Any water on the windshield, will end up on the mirror switch, if the window is cracked. (No smoking when its raining!!!!!!) Quote
91cutty Posted April 10, 2003 Report Posted April 10, 2003 had the same problem on a 92 safari van plus the windows and locks wouldn't work... 11 of the 12 wires running through the conduit between the car and the door had broken over the years. just solder and heat shrink the wires together or use crimp connectors. Quote
Brian P Posted April 10, 2003 Report Posted April 10, 2003 It's good to have spare door panel switches:) Quote
91cutty Posted April 10, 2003 Report Posted April 10, 2003 oops completely forgot... window controls are on the door. Guess that would rule out my theory! Quote
