z34duck Posted March 3, 2006 Report Posted March 3, 2006 Can the oil pump drive seal be replaced on a 1993 3.4 motor without removing the rear head it looks close let me know thank you Quote
Psych0matt Posted March 3, 2006 Report Posted March 3, 2006 Search. its even a sticky EDIT: http://www.w-body.com/forum/viewtopic.php?t=16325 Quote
GutlessSupreme Posted March 3, 2006 Report Posted March 3, 2006 http://www.w-body.com/forum/search.php Quote
mihela816 Posted March 3, 2006 Report Posted March 3, 2006 Guys, that write-up is for the 3.1, not the 3.4 DOHC. The DOHC has a tab on the rear head that blocks the drive from coming up far enough to install the seal. Quote
GutlessSupreme Posted March 3, 2006 Report Posted March 3, 2006 Personally, I said nothing about a write-up. I said: http://www.w-body.com/forum/search.php This HAS been covered before. Quote
fastbird232 Posted March 3, 2006 Report Posted March 3, 2006 I've heard on here you can grind some of that tab off. Quote
slick Posted March 3, 2006 Report Posted March 3, 2006 I've heard on here you can grind some of that tab off. Yep. Quote
