97CuttySupSL Posted March 2, 2006 Report Posted March 2, 2006 so the other day i started my car up..and i noticed somehting weird..my tack was jumpin from about 88rpms to 1200 rpms and the motor sounded like it was going to cut off..as soon as this happens it would jump up to 1200 and do it all over again..possibly the cold??i was told an o2 sensor..i dunno u guys tell me Quote
GP1138 Posted March 2, 2006 Report Posted March 2, 2006 Idle Air Control, most likely. Do an idle relearn. Look in the FAQ section for that. Otherwise, clean yours with gasoline, or I cleaned mine with water, but I really don't recommend that. Quote
19Cutlass94 Posted March 3, 2006 Report Posted March 3, 2006 a vacuum leak would cause bad idle like that, but I doubt it would be a vacuum leak if its that bad. Check the IAC. Quote
THe_DeTAiL3R Posted March 3, 2006 Report Posted March 3, 2006 How much gas did you have in the tank? Low gas+cold temperature=shitty running car. Quote
19Cutlass94 Posted March 3, 2006 Report Posted March 3, 2006 Ive never had that problem and Ive ran with only 1-2 gallons on some pretty cold days Quote
3pt1lumina Posted March 3, 2006 Report Posted March 3, 2006 Vacuum leak then IAC, then TPS if the problems persist. (don't think you'll make it to option 3 though.) Quote
97CuttySupSL Posted March 3, 2006 Author Report Posted March 3, 2006 i ade about a quarter tank wit about 40f degrees out.. ill check the hoses doubt it is them tho Quote
