jeremy Posted March 2, 2006 Report Posted March 2, 2006 Fuel lines...anyone know how to properly bend them?? I have to replace the hard fuel lines that go to and from the vapor canister because they are completely rusted through. The dealership told me that they don't have these lines pre-bent. Is there a proper way to bend these lines in a personaly garage without causing damage? If if wasn't something as important as having to do with the fuel system I would just go to a yard and pull a set in decent condition from there.... thanks in advance for you help Quote
5speedz34 Posted March 2, 2006 Report Posted March 2, 2006 Fuel lines...anyone know how to properly bend them?? I have to replace the hard fuel lines that go to and from the vapor canister because they are completely rusted through. The dealership told me that they don't have these lines pre-bent. Is there a proper way to bend these lines in a personaly garage without causing damage? If if wasn't something as important as having to do with the fuel system I would just go to a yard and pull a set in decent condition from there.... thanks in advance for you help Fuel runs through those lines? Your sure? They have got to sell them pre bent. Edit: You need to get that wheel off so we can look at the fuel filler neck and see what kind of shape that is in. Quote
jeremy Posted March 2, 2006 Author Report Posted March 2, 2006 Fuel runs through those lines? Your sure? They have got to sell them pre bent. I am not sure, I know that it goes to/from the pump/tank....I called three different dealers and they all told me the same thing each one has about 6" of hose on each end of hard metal line... Quote
Turbo231 Posted March 2, 2006 Report Posted March 2, 2006 They sell tubing bender that works well, just note that too much of a bend will restrict flow in the bend. No more then 5 bucks at any DIY car place, such as Advanced Auto Parts or even Sprall*Mart Quote
19Cutlass94 Posted March 2, 2006 Report Posted March 2, 2006 I wsa just gonna saw that theres pipe benders. You can get em in all different sizes, I know we sell like 4 or 5 different kinds of em. Quote
CowboyBilly9Mile Posted March 2, 2006 Report Posted March 2, 2006 A tube bender would be preferred. If you can't find a cheap one to buy then renting is an option. I've also bent tubing around pipe. You want a 2" radius.....bend the tube around a 4" diameter pipe. Quote
jeremy Posted March 4, 2006 Author Report Posted March 4, 2006 I was at the j/y today and I actually grabbed a very solid set of these from another '90 GP, I also looked at a couple of newer w-bodies and found that the lines on those are no longer a hard metal line, that they are plastic, so I pulled a set of those off too. I will put the plastic ones on but I also bought the metal ones in case for some strange ass reason the plastic ones won't work. Grand total spent $8.80 out the door. Quote
19Cutlass94 Posted March 4, 2006 Report Posted March 4, 2006 kick ass! The one hy by my no matter what you get its a min of 10 bucks...NY Quote
