they have two alignment divits/ridges in the hole that mounts on the shaft that would prevent it from fitting, but they can be filed off (as i did mounting an F-150 wheel in my dad's lincoln)
I think you can put the 88-93 wheel on the 94 column, so the opposite would be true too... if the divits/ridges were filed...
It sounds like you need a radio control style 88-93 wheel. it looks much better. I know... I cut off my right foot for a TRUE black one this weekend...
the horn is in the pad. its 2 flexable paltes on either side of the wheel and they are split in the middle by the olds logo so when the bag is deployed it can come out. it should be the basic one wire setup to hook it up like your wheel has now.
correct, the horn hookup is the same.
i'm not sure how well the 94+ wheel will fit, but i know my current 96 gp wheel fit well enough on my 90 steering column to help me move it out of the garage. i didn't put it on all the way, so i don't know how hard that would be
I don't know if you would care, but the 94 wheel blocks the vents. You will NOT get any air or heat to your face/torso with that wheel and that interior.
They should have switched to the 95+ interior in 94, because that wheel with that dash sucks sweaty donkey balls. Looks fine, works horrible.
to get the horn to work on the newer wheel all you do is push the center....I couldn't find one for you at the yard on saturday either...
I like the way that black leather one looks....
BUT , I like the 90 steerwing wheel controls MORE...
They are both nice though....
