TGP Intercooler/Turbo to 3100
is it possible to adapt the intercooler and turbo from a TGP to a Gen 3 3100? If so what kind of work is involved?
the main thing would be you would have to use the rear exhaust manifold and crossover from a TGP. And, you couldnt run a lot of boost cuz your compression ratio is 9.5:1. TGPs compression ratio is 8.8:1. Lower the ratio the more boost you can run. Those are like the main things I can think of that are going to be hard.
Robby
