rear speakers
on a 1998 is it possible to take out the rear speakers without removing the rear seats?
try popping off the speaker covers in the rear deck. you should be able to get to the bolts through there.
if not, alldata says to remove the rear pillar cover and the rear deck cover. you don't want to do that, because it's a btich to get the pillar covers on and off
you could remove the rear window.....
but yeah, you gotta pull the seats.
You may be able to remove the deck cover without removing the C-pilar covers, if you try hard enough, but don't break it!
hmm. i guess so. i never really looked at my mom's lumina's rear deck.
2 or 4 door? alldata says something about rear door speakers, but then the diagram it shows is for the rear deck :roll: .
if the speakers are in the rear deck you'll have to take out the rear deck cover, and that may require removeing the rear seat. on the plus side, removeing the rear seat is really easy
monte carlo so 2 door
and ive tried to remove the carpet and it just wasnt working with me.
so i was just checking if anybody knew an easy way to change out the rear speakers.
Unless the newer Montes are different, which I dont think they are, pulling the seats isn't very hard at all. :? Two bolts on the bottom cushion, pull it out...then four bolts for the seatback and it's free.
I'm not sre if this is the same or not, but on th elumina I just have one retaining strap type of thing that can be removed VAI a crawl inside the trunk...
I hate thos fucking pins, I broke like 3 of them removing the side molding off my lumina :evil:
i hate the plastic screw looking ones.
That's because they are one time use in most cases....the dealer will rape your ass for new ones too, I've heard the jobbers are cheap and break easily though
Unbolt the seat and pull the package tray off... There are the aforementioned PITA clips to remove it behind the rear seat back.
About all you can do.
i was thinking about cutting the carpet away and using the cover from the speakers to hold it down and just have the speakers showing. not hidden by the carpet. any suggestions / warnings?
