Euro Posted February 20, 2006 Report Posted February 20, 2006 Ok, I tried searching this, but came up with nothing on how to remove it. I nightshaded my tails last spring, without sanding the lenses down first. So, of course, when I was done it had ran some, especially on the ends of the lights where it curves This week im trying to remove it via sanding. I started with 400 grit first to see if i can get rid of the deeper shades of it, with no luck does anybody have any suggestions on how to get it off? Quote
ToroToro Posted February 20, 2006 Report Posted February 20, 2006 You can try super clean, acetone, or laquer thinner. If those dont work, get more serious and use aircraft stripper. I definitely wouldn't bother sanding them. Worst come to worst, and those chemicals dont work or fuck up the taillights, just buy new ones. That's pretty much all your options right there. EDIT: I see you only want the runs off. Just keep working on it with sand paper. I dont see why it wouldn't work. Maybe try a wet 400, or dry 220. Then go up from there after you get the runs out. Quote
97CuttySupSL Posted February 20, 2006 Report Posted February 20, 2006 damn good idea u posted this almost did m tails and reverse bars without sanding Quote
Euro Posted February 20, 2006 Author Report Posted February 20, 2006 i'd try the laquer/stripper stuff, but ive got nowhere to use it. I'd do it in my basement, but I actually want to HAVE brain cells when I'm done with it this is the spare tails that I bought from patgizz a while ago, so ive got another set on the car now, if that dont work i'll just do those, if it EVER gets warm here i'll use the aircraft stripper. thanks torotoro Quote
J Posted February 21, 2006 Report Posted February 21, 2006 have me or tony ship you out a new set of tails for the $25 they'd cost here at the jy Quote
Darksyde Posted February 22, 2006 Report Posted February 22, 2006 Did my tails and b/u's last year. It removed easily if you did it withing 5 minutes of spraying. That's about it though IIRC Quote
stockgp Posted February 22, 2006 Report Posted February 22, 2006 i think stripper might crack the acrylic. i think acetone or mineral spirits would be better Quote
