looking for clear corners
does ne body kno were i can get my hands on to get sum clear corners for my 97 cutty sup sl 4dr
Ive e-mailed several companies to see if they could make some/ would do a group buy. Not one has e-mailed me back so Im taking that as a no.
take the lens apart....take out the amber lens, put back together
for some reason I recall that trick doesn't work on our cars, cutlasses at least (that may be just coupes, but I thought both)
i jus checked itr ou would i need to break that seal and if i do how do i go along putting sum sort of a new seal there
yes you will need to break the seal around the edges, and i just used silicone to put them back together.
icic wat did u use to break it jus a sxcrewdriver..i jus dont want to break the lens itself
icic i dunno i got sum shaky hands i might jus go yank a clear corner from the junk yard and practice
ive taken out the amber insert in the corners and just running the gray plastic...hopefully tomrrow ill be able to paint the inside of the plastic red and take sum pics and post them :alcoholic:
