Dark Ride Posted February 18, 2006 Report Posted February 18, 2006 Sorry for asking a question thats probably all over this forum, but I've got a friend who needs a transmission for his 3.1L and I've got a 2.8L trans sitting around with a bad engine. Do they have the same transmissions? I thought they did but I wanna be certain before I start pulling things apart. Thanks, Mitch Quote
Robby1870 Posted February 18, 2006 Report Posted February 18, 2006 Need to know each car these engine/trannys are in. Most likely they are the same, but there is a chance one is a 3spd and the other a 4spd. Quote
Regal_GS_1989 Posted February 18, 2006 Report Posted February 18, 2006 What year of 3.1?? I believe that 93+ got the 4T60-E. If thats the case, than no, your transmission won't work. Other wise, there really is no reason that it shouldn't work. Quote
THe_DeTAiL3R Posted February 19, 2006 Report Posted February 19, 2006 Provided they are both 88-92 or whatever with the 4T60 (non-e), you might need to swap the VSS (vehicle speed sensors) from the tranny.. otherwise the speedo will be off. Not a big deal. Quote
Dark Ride Posted February 19, 2006 Author Report Posted February 19, 2006 Thanks for the info. Its a '92 and a 4-speed so it should work. Thanks, Mitch Quote
