How hard to make your own intake?
I've been thinking about what everyone has been telling me so i'm going with a 3400 head swap on the motor i'm building. I've been told that the 3.1 (LHO) intake has different length runners, thus leading it to suck for performance... what about a 3400 intake? does the same apply?
If so how hard would it be to build your own intake (lower and upper)? I've been thinking more about this, I know that I can use a Plasma-cam (computer controlled plasma cutter) to cut the flat sides (against heads and bottom plate (what is this called?) but after that i'm lost on ideas, do I want exactly the same length runners on every cylinder, also what size runners should I run and what size will be to much (my guess would be match to gasket the entire way on the runner making the runner a rectangular shape).
Also what would have to be done? I know you would have to make a place for the fuel injectors and mounting for the fuel rails. I would also build a place to dirrectly tap nitrous oxide into the runners. Would you have to run vaccum lines with a custom intake like this? also which ones would you have to use if you were to reduce the amount of vaccum lines.
What throdle body would be a wise choice on an intake like this? One off a 3.1, 3100, 3400, possibly a LS1? I would think that the LS1 would make a nice adition but would it leave to much air (being for a 350 SBC? I think thats the size of a LS1?).
If you were to attemp this what type of metal would you use? 1/8 inch stainless? 1/16 inch stailess? or would it have to be thicher. If i chose to do this I'll be doing all of the welding (TIG), and I know you would have to have it pressure and leak tested.
Any suggestions or experience would be very helpful,
Thanks, Eric C.
I've been thinking about what everyone has been telling me so i'm going with a 3400 head swap on the motor i'm building. I've been told that the 3.1 (LHO) intake has different length runners, thus leading it to suck for performance... what about a 3400 intake? does the same apply ?
The 3.1 has long, narrow runners that give it it's strong low- and mid-range power, but that is what limits it's peak output, and kills its high-rpm performance. The 3400 flows much better due to the heads and both intakes. Other than the harder-to-come-by 3500, the 3400 is the ultimate intake swap from pushrod 60V6's. Might as well use that, rather than custom making one yourself.
I don't know about swapping it all onto a 3.1 though (I know for sure you'd have to use the heads as well, if it's even possible).
