ihateallmustangs Posted February 18, 2006 Report Posted February 18, 2006 I bought a stock 2002 delco cd player. No i managed to sqeeze it into my 93 olds dash but the front dash cover hangs out because of it.Also whenever i hit a bump it skips because its kinda just sittin there.Anyone installed one of these before? Quote
slick Posted February 18, 2006 Report Posted February 18, 2006 You might have grabbed a Double Din one instead of a Din and a half. I know there are a lot of fitment issues with a lot of the Cutlass's we get back into the install bay, even with aftermarket radio's. Quote
ihateallmustangs Posted February 18, 2006 Author Report Posted February 18, 2006 SDecondly since my radio was from a grand prix my steering wheel control plug didnt fit. Is it possible to splice a old connector into a new one to make them work again? Quote
Guest Anonymous Posted February 18, 2006 Report Posted February 18, 2006 i doubt it, the interface modules changed over the years. Physically, you could do that, but the internal electronics probably wont cooperate with each other. Quote
LukeZ34 Posted February 18, 2006 Report Posted February 18, 2006 The steering wheel data stream is completely different on the 2002 cars, so your cutlass ones will not work with it. The fitment issues are because the newer Pontiac GP CD Decks are deeper than the original cutlass ones, and the mounting brackets are on the sides which are not removable. Your cutlass requires mounts on the bottom of the radio. Quote
