Grand Moff Joseph Posted February 16, 2006 Report Posted February 16, 2006 Well, by the sounds of it, the steering rack on my Lumina is about out of juice (based on the horrible grinding sound I hear when turning left). Any idea how much these things cost? (part+labor) Also, I was looking for this part on GMPartsdirect.com, and I noticed that you can order either the FE1, FE2, or FE3 steering "gear assembly". I know FE3 is the best suspension package available, but what difference is there between the steering gear for an FE3 car compared to an FE1 car? Quote
Robby1870 Posted February 16, 2006 Report Posted February 16, 2006 The difference is the turning radius and number of steering wheel turns lock to lock. A base rack is 3 full turns lock to lock. There are 2.5 turn and the semi-rare 2.25 turns lock to lock racks. I have a 2.5 turn in my STE and the turning radius is like 3 feet (I think I remember that right) more than a base rack. So, its a little harder to manuever the car in tight places, but, I think, the responsiveness on the highway makes up for that. I barely have to turn the wheel to change lanes. Quote
Grand Moff Joseph Posted February 16, 2006 Author Report Posted February 16, 2006 Oh, I see. Thanks for the info. Any clues on cost?? Quote
19Cutlass94 Posted February 16, 2006 Report Posted February 16, 2006 I can look it up tomorrow for you, since Ill be working... And of couse you know about the core...... Quote
Grand Moff Joseph Posted February 16, 2006 Author Report Posted February 16, 2006 Well, I'm trying to decide if it would be cheaper to buy the part by itself and take it to a shop to be installed, or to buy it from a shop and have it installed there. Either way, the car will go into a shop for the work, because I have neither the time nor the tools nor the space to do it myself. Quote
19Cutlass94 Posted February 16, 2006 Report Posted February 16, 2006 If you buy it and have the shp install it, it will be cheaper cuz shops usually mark up the prices which means you pay more. Quote
jeremy Posted February 16, 2006 Report Posted February 16, 2006 most shops won't install your parts....the only steering rack that I dealt with was on my SHO, so I won't be much help here Quote
1990lumina Posted February 16, 2006 Report Posted February 16, 2006 When the rack was replaced on my Lumina the cost was somewhere around ~$430 after tax, CDN. But the oil pressure sending unit was replaced as well so the cost was $500 or something like that after parts and whatnot. Quote
19902drlumina Posted February 16, 2006 Report Posted February 16, 2006 a rack at a part store ranges from 130-180 takes an afternoon to do it your self so if ure worried about money get a repair manual and go to town Quote
19Cutlass94 Posted February 16, 2006 Report Posted February 16, 2006 he cant work on his car where he is, they wont let him. But you might find a shop that will install it for you. Quote
Bossman429 Posted February 16, 2006 Report Posted February 16, 2006 Labor for rack replacement is 2.9 hours on a 90 Lumina, and that probably doesn't include an alignment. I would figure: Labor: 65/hour * 2.9 = 188.50 Alignment: $62 est. Part (the rack): If they let you buy the parts: ~$180 If they buy the parts, expect some markup, probably: ~$250 Grand total: 188.50 + 250 + 62 = $500.50 Give or take, but that should probably be the higher end of the spectrum. Quote
Grand Moff Joseph Posted February 16, 2006 Author Report Posted February 16, 2006 he cant work on his car where he is, they wont let him. But you might find a shop that will install it for you. Yep, my new apartment complex also has a "no working on your cars" rule. Speaking of which, Jay, I need your address, so I can mail you that emblem for your car. Quote
R Dubya Posted February 16, 2006 Report Posted February 16, 2006 list on a Delco rack for a 90 Lumina is around $400, depending on the package. Aftermarkets are more than likely cheaper. Quote
