92SL Posted February 15, 2006 Report Share Posted February 15, 2006 Does anyone know what this F*&&%$ thing looks like because the ign key cylinder is worn so that when you pull the key it starts dinging. Instead of going through the hassle of replacing the ign cyclider I just want to toss the damn chime module. What color is it 92 supreme 3.1L Quote Link to comment Share on other sites More sharing options...
turby Posted February 15, 2006 Report Share Posted February 15, 2006 Under the dash on the passenger side. Pull the panel off and you'll see the relay center. The rectangle box that is plugged into it is the chime module. About 1" thick, 2" wide and 3" long. Quote Link to comment Share on other sites More sharing options...
GutlessSupreme Posted February 15, 2006 Report Share Posted February 15, 2006 The vary in color, but yours should be a light green IIRC. pretty sure that's what color my '92 Cutlass's was. Quote Link to comment Share on other sites More sharing options...
92SL Posted February 15, 2006 Author Report Share Posted February 15, 2006 thanks guys. One more question:underneath the glove box between the 2 upper vents there is a small hole which looks like a sensor of some sort sits behind with 2 small wires leading from it. What is this? Quote Link to comment Share on other sites More sharing options...
jimmy91444 Posted February 15, 2006 Report Share Posted February 15, 2006 interior temp sensor for your air cond. I think. Quote Link to comment Share on other sites More sharing options...
92SL Posted February 15, 2006 Author Report Share Posted February 15, 2006 I cut the wires thinking it was the chime :shock: int air temp sensor sounds more like it. Not one of my most brilliant moments Quote Link to comment Share on other sites More sharing options...
