Quick vac. line question
At the ends of all the vacuum lines(where the vac. line meets the appropriate plug or sensor), it's a soft line, correct?
Thanks,
Chris
Thanks,
Chris
Umm, no?
uh like where specificly? Sometimes a hard line goes into a soft fitting as a sealant
Guest TurboSedan
Thanks,
Chris
hard vacuum lines (like for the MAP sensor etc) usually go into a soft rubber 'T' fitting that attatches to the sensor itself. is that what you're asking Chris?
I've seen hard lines feed into a piece of regular vacuum hose, feed into accordian shaped somewhat soft rubber fittings, and I've seen them fit into hard rubber (nearly as hard as a tire) fittings.
Thanks,
Chris
Yeah, pretty much. I know there are hard lines, but the fittings are all soft i believe.
