dkorinko Posted February 7, 2006 Report Posted February 7, 2006 Ok guys I have an autometer oil pressure gauge that has three wires coming out of it, one is for power, one for ground and one for the oil reading, is what I would imagine!??? My question is, what what wire can i tap into on the car to get a reading for the oil pressure???? A quick response would be greatly appreciated, thanks Oh and this is on a 97 GTP Dane Quote
sl3196 Posted February 7, 2006 Report Posted February 7, 2006 Umm should have came with a sender. Take out the stock sender above oil filter and put in the new one. Quote
joberlee Posted February 8, 2006 Report Posted February 8, 2006 DON'T get rid of the stock sensor, it is connected to the ecm and has a fuel pump cut out curcuit. there should be a new sending unit just for the guage, if there is no other spot to screw it in you can get a T fitting and screw both into that. Good Luck Quote
sl3196 Posted February 8, 2006 Report Posted February 8, 2006 You can get rid of the stock sensor. It only controls the oil pressure dummy light as far as i've heard. Quote
GutlessSupreme Posted February 8, 2006 Report Posted February 8, 2006 \ said: You can get rid of the stock sensor. It only controls the oil pressure dummy light as far as i've heard. I know that's untrue as far as first gens go.. dunno about second gens. Quote
sl3196 Posted February 8, 2006 Report Posted February 8, 2006 Well I took mine out and haven't had a problem. I was told to keep the stock sender only if I wanted the oil dummy light to function. Most 2nd gen guys don't keep em. Quote
