Hey guys, I'm new to the forum here & I just wanted to know if I can get some advice. car is a 92 cut supreme. It's been idling pretty rough for some time now wit no codes. So far I've changed: plugs(old ones looked pretty good), fuel filter, cat converter, Idle motor, tps. I was told that the ign module has a high failure rate & replaced it with a used one. In the process of doing this I somehow disconnected the map sensor vac hose, so when I went to drive the car it bogged out badly, smelling of gas. So not knowing I accidently removed the map sensor vac hose, I replaced the coil pack & mod with the old one & then realized the hose was undone.
NOw the cars back to it's original state where it idles rough with the occasional "buck" while driving. Question: should I put the other coil pack & module back or could ther be a prob elsewhere?
I would put the other ICM(Ignition Control Module) back on and try it like that. BTW, my car has never thrown a code when the ICM would fail and the car would start to miss.
Fuel pressure regulator?
when my ICM went bad it just died on me once i was getting on the freeway in a turn about, i almost went off the edge.
Neonknight, sorry for making light of it, but that's pretty funny-that would've been a true kodak moment :lol: :lol: . I will put the other icm in & hope for the best. Could the map sensor vac hose being disconnected cause such extreme drivability probs
yup, but I didn't do it until after I drove the car realizing something was wrong. Then I did it. Do you know if you have to do this after every time you disconnect the battery too?
  • 1 month later...
hooha! :smile: thanks for the link kaline. After changing the plug wires that repaired the "bucking" during cruising speeds & IDle relearn combined with a good cleaning with the intake spray ended up with smooth idling & descent acceleration. Thanks for all the info everyonel
