f_399 Posted February 6, 2006 Report Posted February 6, 2006 My friend was following behind me and told me he saw smoke when i tried to overtake the guy in fron of me this was when i stepped on it (WOT) to gain speed to overtake he said it was a puf of white smoke for about a second this is the first time i stepped on it since the intake gaskets were replaced 2nd oil change within 1,000 miles checked the oil and it was full was this bad? Quote
jdcutty Posted February 6, 2006 Report Posted February 6, 2006 Sounds like it is burnin some oil. My fiero did that when I would step on the gas. I checked the oil, full, and the next day it was gone with no external leaks. The case of the magical disappearing oil. Quote
DiscoStudd Posted February 6, 2006 Report Posted February 6, 2006 The valveguide seals are shot. It's not that big of a deal when they wear out, as you're only burning a tiny bit of oil when the engine is under vacuum (like when you're accelerating.) In order to replace the seals, you'll need to fill the combustion chamber (chambers actually - one at a time) with compressed air to hold the valves in place once you take the valvesprings loose (there's a special "tool" that threads into the spark plug hole and connects up to an air hose.) Quote
3pt1lumina Posted February 6, 2006 Report Posted February 6, 2006 Was it blue smoke or white smoke? If it was blue then it was burning oil... If it was white it could be a headgasket (didn't you do the headgasket?) EDIT: I see "white" smoke... so I dunno... free bump. Quote
19Cutlass94 Posted February 7, 2006 Report Posted February 7, 2006 if its white smoke it can also mean your engine is running lean, like a light white smoke, not heavy smoking like a headgasket. I know thats my problem. Quote
DiscoStudd Posted February 7, 2006 Report Posted February 7, 2006 White smoke could also come from a leaky check valve on the master cylinder's vacuum booster (well that and a leaky piston seal on the MC itself.) You could be sucking brake fluid into the intake... Quote
