cardude43 Posted February 4, 2006 Report Posted February 4, 2006 So I'm considering a chip from 60degreev6.com. Just wondering if anyone has an install of it on a 3.4 DOHC. What kind of gain do you see? What should I set the rev limitors to; I'm thinking 7000 rpm in gear and 6500 in N. What do you'll think? http://60degreev6.com/store/index.php?act=viewProd&productId=6 Quote
patgizz Posted February 4, 2006 Report Posted February 4, 2006 why do you need such a high rev limiter in N? kinda useless to sit there and gun it. otherwise ben's chips are the only way to go. it takes alot for me to recommend someone, but i've seen his work firsthand and met him and his stuff is top notch. Quote
Crazy K Posted February 4, 2006 Report Posted February 4, 2006 6500 in N? trying to neutral drop it????? WTF? Don't come talking to us when you're bitching about your tranny blew up and it's shrapnel punched holes in the hood!!! Otherwise, I'm happy with the factory chip myself. The rev limiter is there for a reason, to prevent engine damage. Quote
joey b Posted February 4, 2006 Report Posted February 4, 2006 Ben's chip has performance potential as well. I have my N limiter at 4K and kept my shift points the same (I don't want to burn up my clutches). I also disabled my EGR since it is not possible to keep it in use. Quote
3carz34 Posted February 4, 2006 Report Posted February 4, 2006 You won't be disappointed with Ben's chip, its probably the best add on you can get for the money.Leave your rev limiters in place so you don't wreck stuff !!!! Its expensive to replace blown up tranny's and DOHC's. BRIAN 92 Z-34 FFP stuff so far Quote
cardude43 Posted February 4, 2006 Author Report Posted February 4, 2006 So 4000 in N is okay. What about in gear I guess 7k is too high, so is 6500 okay as well? I don't want to screw up the drivetrain. Any suggestions? I'm not interested with screwing with shift points. Quote
joey b Posted February 4, 2006 Report Posted February 4, 2006 the shift points are set to MPH. stock, I believe, is 6400. Quote
ShockTherapy Posted February 4, 2006 Report Posted February 4, 2006 why do you need such a high rev limiter in N? kinda useless to sit there and gun it. otherwise ben's chips are the only way to go. it takes alot for me to recommend someone, but i've seen his work firsthand and met him and his stuff is top notch. what this guy said. Quote
