3400 headers/intake swap
i have the 3100 on my 95 cutty and was wondering if the 3400 headers from rsm racing would bolt up to the 3100 ... and what year of the 3400 intakes do i need to keep my egr without going through alot of trouble? Thanks Alot! And where can i get a set of 3400 intakes , cant find em at any salvage yards around here ..
First off RSM doesnt make headers, if they do, send me the link cuz I couldnt find any. If you want headers, either have a shop custom make them, because the only headers I know about are for the 3.4 DOHC. as for 3400 intakes, set of '01 will be fine.
S&S makes the headers you are looking for.
You will need to swap the entire top end including heads if you want 3400 intakes.
3400 Series Headers
For optimum flow with normally aspirated
and supercharged engines.
There under-> Grand Am 3400 Products[/b]
yes they fit Grand Am's but the rear header doesn't even come close to fitting the W-chassis
without modifying them? My friend has a set for his old cutlass and the rear collector had to be chopped, shortened, and angled down to fit. If you got them in I'd be very interested in the exact part # and any pics of the install.
that's awesome, seriously. Now that I think of it, the sheetmetal in that area changed in shape in around '93-94, so maybe that was just enough room to make these fit. The cutlass my friend has is an '88.
so pretty much being i have to change the heads to put on the 3400 intakes ... might as well drop an entire 3400 engine in there and be done with it? it does connect to the 3100 harness right? some people say yes some no ... what year 3400 i need so i dont run into any probs with sensors etc... thanks :)
If you want to run your EGR, get an adapter from the 60*V6 Store and get a set of VAN intakes. I have an '01 Alero intake on my car, and it's incompatible with my EGR.
yes it will drop in, if you have a 95 or earlier 3100 then you will loose your dash temp gauge without modification.
You will need to swap over some of your sensors and all of your accessories.
Your harness and computer will run it stock, though its better to get the larger 22.5lb injectors with the 3400 injector harness clips spliced in and DHP tune your computer to take full advatnage of the engine.
http://www.3400swap.com
i was plannin on buyin a 3400 with all sensors and everything already installed on the engine ... would i still have to swap all my sensors off of the 3100 engine?? what is best year and make of gm vehicle that this motor should come out of to make it easy?
you may have to swap some of them depending on the year. You will defentialy need to swap all your mounts and accessories.
I reccomend an 00-02 3400
See http://www.3400swap.com for a detailed guide.
cool , thanks alot =) is it worth the swap , make a big diff from 3100? since u have the motor u would know best , got a price on one that is out of an 01 for $850 , just wondering if it makes a big diff for the money, heh wantin to spend that tax money :D
its a good mod for the money it also opens the door to more power as you continue to mod.
