Foglight wiring diagram, 94-96
Guest Anonymous
I need the wiring diagram out of a FSM for the 94-96 Grand Prix fog light switch, which is part of the headlight switch. It should be the same for the cutlass as well. Thanks in advance.
ill check tomorrow for you on Alldata when im at UTI and get back to ya, i may bave to take pics of the pages on my digicam and e-mail em too ya
Guest Anonymous
well i should hopefully be able to figure some of it out... but thanks for sending it!
if he sent you the schematics, they have the pinouts on them for the connector.
there should be a boxed section on there that says something like fog/driving light switch. the wires going into them will have a letter next to them. those are the pinouts for the switch
here's the pins for a 97 cutlass fog light switch, i imagine they would be the same:
a - light green - high beam headlight feed
b - black - ground
c - gray - interior lamp dim signal
d - empty - n/a
e - brown - park lamp feed
f - fog lamp relay feed -coil
b - black - ground
d - empty - n/a
f - yellow - fog lamp relay feed -coil
