3.1LUMITIC Posted February 1, 2006 Report Posted February 1, 2006 How do i bleed the street rack/pump. I repalce the pump a few months ago b/c my old one went out even after replacing it i still have no power steering. it went out after some fun in the snow i had the wheel to lock for a few seconds while doing donuts and the power steering went out. i think i have an air bubble stuck in the system some where ao i think ineed to bleed it. so can anyone help me? Quote
White93z34 Posted February 1, 2006 Report Posted February 1, 2006 when i had alota air in my system i just let the pump run with the cap off for awhile and it left that way, but if you have zero power assist, i think theres problems elsewhere then air in the lines. Quote
3.1LUMITIC Posted February 1, 2006 Author Report Posted February 1, 2006 it has some assistance its not arm wreching to turn the wheel. but what other problem do think i might have when i let go of the wheel it goes strightso i dont know... Quote
Guest TurboSedan Posted February 1, 2006 Report Posted February 1, 2006 when i had alota air in my system i just let the pump run with the cap off for awhile and it left that way, but if you have zero power assist, i think theres problems elsewhere then air in the lines. i think usually you just need to spin the wheel from lock-to-lock a few times with the cap off (and add fluid as needed). should get quiet pretty quick. although my brother just had the same problem last week when he installed a new PS pump. he had no assist and couldn't figure it out. the pump finally started pumping enough fluid when he revved the engine up high, then it started working. sounds wierd but that's how it worked. he replaced the rack at the same time so maybe it just had a ton of air in the system Quote
Guest TurboSedan Posted February 1, 2006 Report Posted February 1, 2006 it has some assistance its not arm wreching to turn the wheel. but what other problem do think i might have when i let go of the wheel it goes strightso i dont know... slipping belt on pump pulley? bad pump bearings maybe? Quote
3.1LUMITIC Posted February 1, 2006 Author Report Posted February 1, 2006 pump is new no slipping belt even at high rpms its still the same... but is there a way to bleed the rack? Quote
GutlessSupreme Posted February 1, 2006 Report Posted February 1, 2006 i think usually you just need to spin the wheel from lock-to-lock a few times with the cap off (and add fluid as needed). ^^^ The "proper" proceedure according to the FSM is: BLEEDING THE POWER STEERING SYSTEM 1. Begin with engine off' date=' front wheels off the ground, and wheels turned all the way to the left. 2. Add either standard power steering fluid or optional cold climate fluid, to the "FULL COLD" mark on the fluid level indicator. 3. Bleed the system by turning the wheels from side to side without hitting stops. [b']Important:[/b] This may require turning the wheels from side to side several times. Keep the level at the "FULL COLD" mark. Fluid with air in it has a light tan apperance. This air must be eliminated from the fluid before normal steering action can be obtained. 4. Start the engine. With the engine idling, recheck the fluid level. If necessary, add fluid to bring to "FULL COLD" mark. 5. Return the wheels to the center position. Lower the front wheels to the ground. Continue running the engine for two or three minutes. 6. Test the vehicle to be sure the steering functions normally and is free from noise. Important: Inspect for fluid leakage at the connection points along the power steering system. 7. Recheck the fluid level as described in Steps 3 and 4 except that the fluid level should be up to the "FULL HOT" mark after the system has stabilized at its normal operating temperature. Quote
3.1LUMITIC Posted February 1, 2006 Author Report Posted February 1, 2006 that helps a bit but where the bleeder screw at? Quote
GOT2B GM Posted February 2, 2006 Report Posted February 2, 2006 Just turn your steering wheel lock to lock several times with the power steering reservoir cap off, with your engine running. Quote
mihela816 Posted February 2, 2006 Report Posted February 2, 2006 There is no bleeder screw as the reservoir is the highest point in the system. Quote
3.1LUMITIC Posted February 2, 2006 Author Report Posted February 2, 2006 ok but is there a way to bleed the rack? Quote
Crazy K Posted February 2, 2006 Report Posted February 2, 2006 turning side to side forces fluid to flow through the rack, forcing air to move out of the rack, to the reservoir. Quote
3.1LUMITIC Posted February 2, 2006 Author Report Posted February 2, 2006 ok ty very much and sorry i though i read theres no bleeder screw in the reservoir and i was thinking there might be one some where esle... Quote
