f_399 Posted January 31, 2006 Report Posted January 31, 2006 http://cgi.ebay.com/ebaymotors/95-01-New-GM-Lumina-Drivers-Master-Power-Window-Switch_W0QQcmdZViewItemQQcategoryZ50459QQitemZ8033675137QQrdZ1QQsspagenameZWDVW#ebayphotohosting window switch is not working in the lumina, all other windows dont work eitherl you think this is the problem? Quote
cutty Posted January 31, 2006 Report Posted January 31, 2006 do the windows work when you use the other swithces on the other doors? Quote
f_399 Posted January 31, 2006 Author Report Posted January 31, 2006 nope this thing gave me problems before, i just hit it then all windows work again maybe i hit it too hard this time Quote
cutlass1991 Posted January 31, 2006 Report Posted January 31, 2006 The main drivers window switch distributes power to the other three window switches so I think it is safe to say the problem is in the drivers door switch. I would pop it out of the door and make sure the harness is plugged in tightly. If hitting it makes it work, it could be a loose contact inside the switch itself. Quote
f_399 Posted January 31, 2006 Author Report Posted January 31, 2006 bidding on this http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=8033051983&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1 Quote
Crazy K Posted January 31, 2006 Report Posted January 31, 2006 Try removing the switch, and checking the contacts for corrosion. it is very easy for corrosion to get on the switch as it get wet whenever you open your door in the rain. If you find corrosion, sprape as much of it as you cna away with a pin or paper clip. I then coat the contacts with something like bulb grease or silcone grease to keep out moisture. I think the switch is self is most likely fine. Quote
f_399 Posted February 4, 2006 Author Report Posted February 4, 2006 is there a way to put any of the other windows down with the drivers side master switch broken? man i have a broken a/c, a vacuum leak and windows dont go down! Quote
cutlass1991 Posted February 4, 2006 Report Posted February 4, 2006 If you pull the switch out of any other door, you need to find the blue and brown wires. put +12v to one wire and ground to the other. One way is up, and if you flip the +12v and ground wires, it'll go the other direction. Quote
