So, with AWeb's rear STB coming, Im looking to turn the box around so the speaker points towards the back of the car.
this is how it looks now(wires arent so messy now)
the charoal-ish colored wire going to the bottom of the picture is the ground, can i ground it on the strut tower bolt...then bolt the rear STB over it?
I really can't see why not. I had a ground on the strut tower of my old sunfire. Word really good as a ground. Much better than the seat belt bolt, thats for sure.
As long as you have a good clean connection to the chassis, you should be able to put it there.
ok thanks...i should have a clean connection...we put it around the tower as a test before we decided on a place..and it worked good
thanks again!
The ground Im using right now is the little tab by the antenna. It would good, never had a problem so far *knock on wook* but its hard to tell.
when you face the sub towards the back of the car, youll get alot more sound.
thats ok with me.....i just thought it looked horrid(see first post) :lol:
