Transmission cooler lines (not auxiliary cooler)
For the stock cooler lines that run through the coolant radiator, does anyone know the correct routing for the two lines? Last weekend i got distracted when replacing both rubber lines and completely blanked out on where each went. The helm diagram isnt clear either. Coming out of the tranny are two metal lines in the same area; one pointing straight and the other towards the passenger side. I need to know where each go, to the upper radiator entrance or lower. This is for an '89 GP style radiator with 4T60. Thanks.
well to me it doesnt matter but the side that pumps it should go up top im not sure but iwould think if the return line was at top it would be harder to get the fluid up but idk. if this helps
david
