UPDATE!!!!!!!!!!!!!!!!!!!!!!!!!! speedo prob RESOLVED horray
OK I JUST GOT THIS CAR and have had many chevys pontiac6000s and celebritys and never had this happen. going 70 it says im doing 115 90 its no longer on the speedo (wife in front thats how i know how fast i was going) when i hit full speedo it the fuel cut out gets reached and cuts out till i slow down. is this the speed sensor? or something entirely different?
thanks
UPDATE alrighty i found the problem and it was a prom/memcal chip the speed is dead on and just horray . theold comp was probly from a newer car as i got 2 chips from the yard new one and same year is perfect hope this can help someone else one day david
Yes, I would be inclinded to say that you may have some faulty speed sensors. I've never had to replace mine, so I'm not sure how to advise you to do that. Try doing a search on the forum to see what else you can dig up too.
Btw, try not to use too many CAPS. On the internet that means you're yelling. Welcome to our forum too. :lol:
I put the UB3 cluster in my car, and now it reads 5mph faster than what the car is actually moving. I don't know why because the stock cluster still reads exact.
Is this the same problem?
I think he is saying that his car actually speed governs because it thinks it is going faster then it really is?? Or did I miss read?
I not 100% sure how the speedos work on these cars, so someone correct me if i'm wrong, but the speed sensor sends pulses to the ECM, which than detects the speed of the pulses and that detects your speed. If your hitting the speed limiter, when your not really going that fast, i would say that there is something wrong with the ECM. I have never seen a defective speed sensor that read overly high. I am under the impression that if the sensor fails, the speedo just wont work. :shrug:
regal gs 1989 i think is right. i thought it would just fail too. as for the cluster i dont know for sure i just got it yesterday. but its way over 5 mph more. i will try the speed sensor first as the car has 179k on it. when i hit over 115 mph on the cluster the fuel cut off kicks in.
well it may not be as far off as you think then. The fuel cut off happens between 112mph and 115mph depending on model with the 3.1 or 3100.
thanks for all the help guys when i get the cash up ill tell ya if its fixed
david
It's more than likely someone changed the PCM with a used one, and did not transfer the MEMCAL removeable chip in the PCM from the original one to the "new" one. You would need one from a 1990 car with the same transmission.
cause im planning on a chip upgrade anyway but if the speed sensor doesnt fix it i have a reason to tell the wife for the chip :D
depends on which chip. Some of them don't replace the memcal that's in the PCM so you'd have the same issue.
  • 3 weeks later...
alright i put a new computer in and same thing took out speedo and its a reman.and the odo-sprocket came off so its not reading miles so ive got a newspeedo on the way and probly gonna replace the vss
  • 2 weeks later...
bump??? whats the current status? I just got a ticket due to a wrong speedo... I think... But I think the cop got the wrong car... My car can't go as fast as he said i was going, even down hill :lol:
well i put an update on the first page where i origanlly stated problem. my speedo reads 10faster at thats at 40 wife in front my car says 50-51/2 well i bought the vss/nope same bought the ecm nope same and a new cluster guess what ....................nope not fixed so my problem is is md is strict on theyre inspections and this needs to be fixed and soon cause we need two cars with a 1 yr old, and throwing money at it isnt helping i just need help finding whats wrong i heard a trans swap could do it but i have no prior service records. ive found 2-3 others with same problem just waiting to hear back how they fixed it. i love this car and if it cant get fixed im gonna have to get rid of it :cry:
Are the tires the correct size? If you have the original trunk lid, it should be on a sticker tag on the lid... read it and compare your tire size.... in fact post it here, I can find a chart to get the exact measurements...
and apparently mine aren't.... not even close, according to the research i did...
I had my CC set to 65. IT is an ambigeous rural interstate where the speed limit is (or should Be?) 65. The max speed I reached when I gave is some pedal was 72... he said I was doing 90... whats a town cop doing partolling the interstate anyhow????
he doesnt have juristicion on intstates anyway right? i thought staties were the only ones who could pull u over on the highway. but hey what do i know
Thats what I thought... anyhow I was running with my CB on, so I knew he was there, in traffic behind me... and that there was a highway patrol a mile or so ahead of me in the median.... so why in the world would i be speeding??? duh.... something is not right here... 90 would be flying, and my car doesn't have much left of it's original horses... it really really has to strain to get to 80....
ok, back to topic.... so... Your limiter kicks in when your speedo hits '120' even if you are doing like 90 as measured by a pacing car. correct?
I guess the question to ponder is if your car has an actual limiter at 119, or something like 89 or something??? It's rumored that all the luminas had limiters at 119, but I wonder if a base model prom ship would affect it?
I am about to test some extra prom chips I bought, one was from a 92 euro, and one was from a 90, to see if they affect the car's operation, or speedo reading....
The risk or using a prom chip from a junk car is that if it is configured incorrectly for you car, it might make it run bad..... (I wonder if I have this problem anyhow, seeing my car seems anemic anyways? Or maybe it's just 210k on a never rebuilt motor?)
