What should I do?
Well, my new PCV tube (broke the old one) is coming in wednesday, the plenum is off and clean, what should I do while the plenum is off? any sensors I should change to help it run better? Clean the grounds?
Throw some screws down those little holes.
and throw in some water to clean it out, too
urinate in it!!! Uric acid does wonders for aluminum!
I always yank and inspect the fuel rail while I'm there.... test the injectors for proper resistance, and inspect and replace the injector O-rings, expecially if you have never done so before.
pour some sand down there, that will clean varnish off the valves.
Guest TurboSedan
there aren't any sensors under the plenum, but you could replace the dist. o-ring while you have the plenum & TB off. you could also replace the injector o-rings while you're at it. oh....be sure to inspect the vacuum lines and replace them if necessary.
x2 x2 x2 x2 x2 x2 x2 x2
I didn't necessarily mean sensors under the plenum, I just meant things that would be easier to get to or just anything in general since the car isn't running and I'm waiting for parts
Hey! We understand!
BTW was it bad for me to leave the rags in the intake holes when I put together my brothers old pontiac 6000? :lol:
