Steve Williamson Posted January 29, 2006 Report Posted January 29, 2006 Driving down the road the car just shuts off.It starts back up imediately.No wait. It does not lunge or run rough before this happens.It like the key is turned off.Changed the EGR valve,ignition module,the 3 coils and also the map sensor with the manifold it snaps onto. The error code is 32(EGR fault). After al these repairs it shut down again after 500 miles. Quote
White93z34 Posted January 29, 2006 Report Posted January 29, 2006 how often does it do this? i know my z34 will stall once in a while, but certinally not enough for me to care about. Quote
birdman Posted January 29, 2006 Report Posted January 29, 2006 phantom stalling injectors mabey? those usually dont so it that much though. mabey a short in the egr circut, id check that. Quote
jdcutty Posted January 29, 2006 Report Posted January 29, 2006 Does everything turn off then turn back on (i.e. guages, lights, etc...)? If so it could be a loose connection at your aux batt post. i think that has prolly happened to all of us. Quote
creepin_olds Posted January 29, 2006 Report Posted January 29, 2006 a lot of people do not think about this one, Check your alterantor and your battery Quote
Steve Williamson Posted January 30, 2006 Author Report Posted January 30, 2006 The alternator and battery were new last year. Before this problem started occuring. Quote
97CuttySupSL Posted January 30, 2006 Report Posted January 30, 2006 my cutl;ass will do it wen i rev the motor up and then throw it dowbn to drive after it hits about 1000 prms it starts to rev and dies then i can restart wt no problem Quote
dsgrntld187 Posted January 31, 2006 Report Posted January 31, 2006 The alternator and battery were new last year. Before this problem started occuring. Still, check the battery terminals and the alternator terminals. Quote
skiiirt Posted January 31, 2006 Report Posted January 31, 2006 replacing an egr valve is not always the end all solution. U may have carbon buildup in the intake Go buy like 3 bottles of Top Engine Cleaner and use that Quote
joey b Posted February 1, 2006 Report Posted February 1, 2006 I got 10 bucks saying it is injectors. You have to get some that are 94 and up. I replaced mine about 18 months ago cause It would stall ALL the time. If I were in a traffic jam it would stall about once every 5 minutes when I let off of the gas. Replaced the injectors with some that I bought off of ebay for 50 bucks and it hasn't happened since. Quote
97CuttySupSL Posted February 1, 2006 Report Posted February 1, 2006 ya i heard itmight be injectors Quote
