LuminaMan93 Posted January 28, 2006 Report Posted January 28, 2006 I pulled the rear swaybar off of a DOHC Cutlass last weekend. I'm pretty sure it had the FE3 suspension. How do I tell if it is an FE3 swaybar? And what size it is? Quote
Crazy K Posted January 28, 2006 Report Posted January 28, 2006 I think that the rear sway bars are all identical, period. My 95 CS has FE1 suspension and it has the same rear sway bar as my 91 lumina FE3 donor suspension, (put on my 92 lumina) Can you give us a shaft diameter for others to check against? without regard to being fe1 or fe3, There must be an fe1 upgrade option that gives you the fe1 springs with fe3 sway bars, but if it is on my spid tag, its a code I can't decode. Quote
TeeJay3800 Posted January 28, 2006 Report Posted January 28, 2006 I am 99% sure that FE3's had larger rear sway bars. Mine is FE1 and has a much smaller bar than the International Cutlass I saw in the salvage yard. Quote
