Mr.ChevZ34 Posted January 27, 2006 Report Share Posted January 27, 2006 Hey guys, I've got a problem cuz i have no dash lights or centre console for that matter. I checked all fuses but am gunna check out the flasher fuses cuz apparently that may be why.Ideas? Quote Link to comment Share on other sites More sharing options...
chadz34 Posted January 27, 2006 Report Share Posted January 27, 2006 Did you put in an aftermarket CD player? Some people I know have had their dash lights go out when they put a new CD player in. Quote Link to comment Share on other sites More sharing options...
Crazy K Posted January 27, 2006 Report Share Posted January 27, 2006 dash lights? as in the backlighting that goes with the parking lights???? They use a seperate 5 amp fuse, I burned mine out while installing my HUD, and the fuse actuallly tested good on a continuity test, but turned out to be bad. try another fuse, and if that's not it, did it happen due to a radio install as suggested above??? Quote Link to comment Share on other sites More sharing options...
Prospeeder Posted January 27, 2006 Report Share Posted January 27, 2006 You did check the obvious like some1 messed with the dimmer switch right? A fuse sounds like the problem Quote Link to comment Share on other sites More sharing options...
19Cutlass94 Posted January 28, 2006 Report Share Posted January 28, 2006 Like stated above, the fuse has gotta be the problem because the chance that every bulb burned out is slim to none. Quote Link to comment Share on other sites More sharing options...
Mr.ChevZ34 Posted February 14, 2006 Author Report Share Posted February 14, 2006 No, my dimmer switch hasn't been played with and i have checked my fuse and it appears to be okay. The car had a stereo swap but nothing was in it when i got it. There are 3 wires by my steering shaft that are clipped. There is a thicker red one that has power and is attached to my light panel ( parking and regular lights ), a green wire that is kinda thin and im not sure if it has power, and a black ground that is grounded by the steering shaft itself but leads to nothing....its just attached to space. Im wondering if this is my problem and also if anybody knows what this may be. Quote Link to comment Share on other sites More sharing options...
