stockgp Posted January 27, 2006 Report Posted January 27, 2006 dealers can only give them to me if i buy wheel cylinders. the three chain parts stores in town are the same, and the one independent store only has sae fittings. how the fuck am i supposed to get new ones? Quote
Bossman429 Posted January 27, 2006 Report Posted January 27, 2006 I have seen them in SAE and Metric at Carquest. I believe they are in the HELP section actually. You may need to bring in one good one to get the correct size, they don't have an application book to look it up at. EDIT: On second thought, you may consider just replacing the wheel cylinder. A bleeder screw will probably run about $4 or so, whereas a new wheel cylinder will run about $12-15. Espcially if you can't find the bleeder screw this may be the only solution. Quote
stockgp Posted January 27, 2006 Author Report Posted January 27, 2006 hmm. i figured wheel cylinders would be more. id didn't even bother asking . anyhow, my brother called a guy he knew at one of the parts stores i called and now they've decided they have them Quote
Bossman429 Posted January 27, 2006 Report Posted January 27, 2006 Yeah, at Carquest they have premium and cheap wheel cylinders. Cheap ones are around $15. Expensive ones are like $35! Get cheap ones, they are so simple, I'd never pay more than $20 for one. Quote
stockgp Posted January 27, 2006 Author Report Posted January 27, 2006 the closest carquest to me is a good 1/2 hour away from me. just my luck, huh. well thanks for the tip. if it comes down to it, i wll go to carquest Quote
pwmin Posted January 27, 2006 Report Posted January 27, 2006 as was mentioned, they should have them i the help/motormite section Quote
19Cutlass94 Posted January 28, 2006 Report Posted January 28, 2006 NAPA has bleeder screws. If thats all you need, but they also have wheel cylinders and everything else you need. Quote
95oldsVan Posted January 28, 2006 Report Posted January 28, 2006 Ever think about getting the speed-bleeders? They help you bleed the air out of the calipers without allowing air back inside.This is a popular mod to people who race their cars alot and or do their brakes at home alot and need something that wont allow air to get back in the caliper. Just a thought. Quote
joey b Posted January 28, 2006 Report Posted January 28, 2006 how do you remove a broken off bleeder screw? Quote
Crazy K Posted January 28, 2006 Report Posted January 28, 2006 you could try an easy out........ or just replace the cliper or wheel cylinder! I actually will coat the upper thread of the bleeder with antisieze. it it's handy or problematic. enough to prevent waer from trickingintino the threads, but without contaminating the fluid. Quote
