new to w-body and would like to know if you can see the ub3 cluster in a convertible with the top down ? also what year can i use fo a 94 cutlass with a 3100?
Given the overhang that is built into the Cutlass dash, I don't think sunlight/glare would be a problem for you. Are you trying to swap a UB3 into a non-UB3 car?
BTW, welcome to the boards!
PS-If you are trying to do a cluster swap, and have not yet found a UB3, I have one to sell to you :)
Well, I don't have any pictures of the specific one I have for sale, but there are some pictures of another member's Cutty covertible that has a UB3 from the factory in the following link:
http://www.w-body.com/forum/viewtopic.php?t=36479&postdays=0&postorder=asc&highlight=ub3&start=15
A better pic of the UB3 can be seen here:
http://www.w-body.com/forum/viewtopic.php?t=33311&highlight=ub3
Basically, if you want to do the swap, you'll need a cluster (obviously), and you'll need to change the pinouts in the wiring harness that connects to your gauge cluster. You can either:
A) Do it yourself
B) Purchase a wiring adapter from one of our members
http://www.w-body.com/forum/viewtopic.php?t=31378
into my vert...
and they only had the ub3s up til 91 or 92 (i forget) so yes, you have to get an older one. The pinouts are on the main w-body page, but be forewarned, I've heard of some people having major troubles putting one into a 94. I think i have some other helpful things i got from other members if you get stuck, but mine was very straightforward, except for a dimming problem I have yet to fix (it goes about half dim with the lights on, but doesnt dim variably like it's supposed to, but I almost like it)
edit: Oh yeah, and I dont ever remember having a problem seeing it, those suckers are bright!
i will have to go to the jy and pick one out i had seen 3 of them there what is a good price for one
probably anything around 40$ or less would be about fair, don't pay more than like 60ish though, they can be had for under that. Check out ebay too, they sometimes have some
There was a member on here that claimed it was very difficult to see with the top down, FWIW.
who cares, you have a vert.... :lol:
i will have to make up my mind then on it .this is my 3rd vert and i want to make it diff then the other 2
If it's too hard to see you could always change it back...
If digital was possible to put in my car, you bet I'd be trying to swap it in!
http://www.w-body.com/forum/viewtopic.php?t=38206
There is one for sale by GMF. Good deal too.
Yep, that would be me.
BTW, my username is GMJ, NOT GMF
Hence, "Grand Moff Joseph"
:oops: :oops: :oops:
I knew it was you...but definetly got the name mixed up....hopefully you sell the cluster tho...great deal!!
yes i know i can switch it back but when it is in it will stay in then i can get a hud and a dis to go with it!!!
  • 1 month later...
the RPO code is actually UB3 for your original dash...that's the digital UB3...it looks cool, but my car has HUD so i really don't see a reason to change. I do have an extra cluster at my house though
need the pinouts for a 94 can anyone help?
Check the other thread of yours about hooking up the DIC. I'm pretty sure I posted it there.
Get the UB3 from a j/y with one of those wiring harness from another member is the way to go. It makes life much simpler to go back and forth between instrument gages and installation is a snap. The issues I have had with the gage swap was dimming of the cluster and making the tack work. Those things are easily fixed by splicing into some wires. I usually don't have any problems with viewing the UB3 with my top down, I say go for it. I bought my UB3 at a local j/y for $25.
got the ub3 put in today ! just need to fix the dimmer and put in a oil sender now
