96mcls Posted January 26, 2006 Report Posted January 26, 2006 my car is in need of new front struts( it's a 1996 Monte Carlo LS), and i was wanting to get it a little lower, so i was thinking of getting some springs also, and do the rear struts too my question is, which springs do you guys recommend intrax or Eibach i am going to use KYB GR-2's for the front and back. also i was planning on replacing the strut mounts as well, any recommendations, i was just planning to get some from autozone. also i need to replace what i think is the inner tie rod end(i get a vibration at high way speeds) but from what i hear this is a real pain to do, so i was thinking about letting the shop i take it to replace it when i get an alignment. it might take me a while longer to do this project than i had hoped, i calculated the cost and i'm half way there, well i was, then i bought a few new tools i thought would help in the process (ie. new 3 ton jack to replace the POS 2 ton that doesn't even get my car's wheel off the ground , spring compressors...) any thing else i should replace? i was thinking about replacing the ball joints and the other outer tie rods. and i got i few extra goodies to go on as well, rear discs(well i had those but were removed for a while for abs problems, turns out i pinched a wire and replaced the whole set up back to drums for no reason :x ), e-brake cables, and a z34 rear sway bar. Quote
slick Posted January 26, 2006 Report Posted January 26, 2006 Personally, i'd go with the Eibachs. They may not get you as low as the Intrax, but they will handle 10x better. Quote
Cam'ron Posted January 26, 2006 Report Posted January 26, 2006 havent done a drop suspension yet but if and when i do i am going eibach Quote
Guest TurboSedan Posted January 26, 2006 Report Posted January 26, 2006 Personally, i'd go with the Eibachs. They may not get you as low as the Intrax, but they will handle 10x better. why do you say that? i haven't been able to compare yet, but i should be able to soon. i have Eibach springs in the Cutlass and my Intrax springs are going in the STE soon. Quote
slick Posted January 26, 2006 Report Posted January 26, 2006 I know on other cars besides for W's, it's been proven that the Intrax will go lower than the Eibach's, even after settling, but the Eibach's handle much better than the Intrax. Quote
Pabz Posted January 26, 2006 Report Posted January 26, 2006 Intrax are good enough. Eibachs must be great but I dont see W-body's taking advantage of that greatness. Whats the price difference? Quote
19Cutlass94 Posted January 26, 2006 Report Posted January 26, 2006 I cant imagine unless you autocross, it really dont matter which one.... just what you looking for I guess. Quote
Psych0matt Posted January 26, 2006 Report Posted January 26, 2006 I cant imagine unless you autocross, it really dont matter which one.... just what you looking for I guess. I wouldn't think it would be that amazing of a difference for most of us average drivers that just want a drop and a bit of handling increase. Quote
pwmin Posted January 26, 2006 Report Posted January 26, 2006 just an fyi, the rear is going to look a little higher than the front with the eibachs, at least from what ive seen. not sure about the intrax Quote
