Fuel Pump pumps no more...
Well I decided to go for a quick drive in the TGP to go pick up a Papa Murphy's pizza. When I made the turn into the parking lot I heard a howl come from the fuel pump. The car never sputtered, but when I came back out of the pizza place to start the car....SHE NO WORKY!!! :cry: :cry: :cry:
So what fuel pumps should I be looking at to replace this one guys... 8)
The fuel pump you need is an ACDelco part # EP375
It is the same one as the vette uses. :wink: :cheers:
Thanks man... 8)
Do you think the stock fuel pump will supply enough fuel if I decide to run 30# injectors and 18PSI of boost? 8)
It has enough, it can (it does) supply a vette V-8!!! it is what Jeff M recomends, and what I'm using on my red 89 that I'm in the process of putting the ported and polished heads and 29lb injectors into... A jeffm test bed :shock: :shock: :shock: :devil: :mrgreen: :cheers:
