z34_nut Posted January 23, 2006 Report Posted January 23, 2006 So I already checked out the FAQ section, didn't find anything... how do you change the date on an 88-93 DIC? This is the DIC I have... thanks guys Quote
THe_DeTAiL3R Posted January 23, 2006 Report Posted January 23, 2006 There should be "mode" and "set" (unless it's a little different, mine is from 88 GP). Use mode to select what you want to change, and set to change the number. Quote
z34_nut Posted January 23, 2006 Author Report Posted January 23, 2006 Do I have to make sure its on the date part? (of course what am I thinking?) Quote
Robby1870 Posted January 23, 2006 Report Posted January 23, 2006 Do I have to make sure its on the date part? (of course what am I thinking?) Yeah, as you hit mode to go through things like date, time, language, etc, each time you hit mode you'll switch to a different part of the date, like days, month, year. Hit set on each one of these until the right number shows up. Quote
z34_nut Posted January 23, 2006 Author Report Posted January 23, 2006 This should definatly be in the FAQ, and thanks for the help, its not 1989 anymore. Quote
Guest Anonymous Posted January 23, 2006 Report Posted January 23, 2006 if the date shit out on you the compass probably did too, did you figure that out? Its ridiculous what you have to do to set it, too. Quote
z34_nut Posted January 23, 2006 Author Report Posted January 23, 2006 yeah, I set it right after you explained it. Driving around in circles and such... I also found that a nice EASY way to do it is just point your car north, and disconnect your batt... Quote
